Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Alias 2024.1 crashes at startup
2 REPLIES 2
alexanderP83CN
371 Views, 2 Replies
I have been using the 2024.0 and 2024.1 Learning Editions for many months now and it has worked great. Then recently I tried to change a custom marking menu I had previously set up and Alias 2024.1 crashed and now it crashes at Startup every time.
I have tried to reinstall 2024.1 (+wipe all prefs that remained after uninstall) but it still crashes. 2024.0 still works but not 2024.1.
This is what the error log in "errlog2024" tells me:
License Authorize LearningEdition, C63P1, 2024.0.0.F
Unable to load library 'C:\Program Files\Autodesk\AliasLearningEdition2024.1\bin\libextensions.dll':
Error in library load.
Could not install C:\Program Files\Autodesk\AliasLearningEdition2024.1\ODS\OpenAlias\plugins\Modeling\lib\globalCrvIntersect.plugin (Already installed)
Color definition couldn't be found: cellBorder
Color definition couldn't be found: comboxBoxHightlight
Color definition couldn't be found: checkBoxTriStateCheckedMid
Color definition couldn't be found: checkBoxTriStateCheckedFill
Color definition couldn't be found: checkBoxTriStateBorder
License Release LearningEdition, C63P1, 2024.0.0.F
Alias terminated abnormally at Thu Mar 14 16:43:04 2024
Any idea of how to solve this? I feel like I can rule out hardware issues since I've used the 2024.1 version for many months without any problems whatsoever. But I have no idea of how to solve this. Help 🙂
2 REPLIES 2
bob55
in reply to: alexanderP83CN
removal of
%APPDATA%\Autodesk\Alias\UserPrefs2024.1
directory (or rename) should fix the problem.  And if that's the case please zip up the preferences and post them here.
alexanderP83CN
in reply to: bob55
Thank you, that worked!! I can't believe I missed the folder in the AppData! Thanks!
