The installer is comprised of 2 zip files...you need to wait until both are downloaded and unzipped to install Alias...or there are missing files the installer requires...
@Anonymous wrote:I have this problem with Alias
did you get any proper solution?, I am also facing the same issue.
As Barry already mentioned in his reply: the installer consists of two files which you need both. If you try to install while only one of these two files are present (completely downloaded) on your drive, you will see this error message.
Hth
Thomas
@rauscht quickpayportal wrote:As Barry already mentioned in his reply: the installer consists of two files which you need both. If you try to install while only one of these two files are present (completely downloaded) on your drive, you will see this error message.
Hth
Thomas
Thanks.
