Alias 2021 update problem
I have this problem with Alias
BarryKimball
The installer is comprised of 2 zip files...you need to wait until both are downloaded and unzipped to install Alias...or there are missing files the installer requires...
did you get any proper solution?, I am also facing the same issue.
rauscht
As Barry already mentioned in his reply: the installer consists of two files which you need both. If you try to install while only one of these two files are present (completely downloaded) on your drive, you will see this error message.
Hth
Thomas
Thomas Rausch
Software Development Manager
Hth
Thomas
Thanks.
