Alias 2016 Directconnect Problem
For some reason I cannot import .stp, .catpart files into an Alias 2016 session.  I get the following failure message:
"Translation of (part name) failed due to DirectConnect not being installed".  What steps need to be taken in order to address this issue?
Just install DIRECTCONNECT.
From your istallation media, look for:
\x64\DirectConnect\AutodeskDirectConnect10.0.msi
After installing directconnect your should be able to import tose files
Please mark accept as solution if it solved the problem
Actually, my IT department must have figured it out prior to your response, but thanks for the help nevertheless!
