Add Extreme Left or Extreme Right hole point definition for dimension requests
Hello, Ref. screenshots below, we need a new point definition "Extreme left" and "Extreme right" for the first and last points of a hole pattern:
7 Comments
Hi
For the current beam drawing style you can do the following change:
For columns drawing style is a little bit trickier, since a change for current settings will affect other situations too, therefore you need to create new dimension rules.
acbsdesign
@gabriel.costin
Thank you for the screenshots and the info, I tried this-it is not working.
Did you test it-if yes-can you please take a screenshot of the results.
For both holes in webs and for holes in flanges.
Thank you very much.
Ilko Dimitrov
ACBS
Attached is my result:
Make sure to apply "Left-Extreme" for both records:
Mp - Bo+Ho Tv Li
Mp - Bo+Ho BothFl Fr AllPoints
acbsdesign
@gabriel.costin
You are the best!!!!
And Dumitru, of course.
Thank you very much,
It would be nicer for everyone to have this set-up by default.
Thank you again for your help.
Ilko Dimitrov
ACBS
acbsdesign
@gabriel.costin
Works as a charm, and another small thing I need to polish, ref. screenshot below-when holes in top and bottom flanges are at the same distance from the left end, ONLY the ones on top flanges are dimensioned.
Can you please show us hot to add the missing clouded dim's, hope I am not pain in the neck....Thank you.
Please check the following option for the marked dimension rule:
acbsdesign
@gabriel.costin
It works like a charm.
