Token (Or script) for Camera Elevation in Plan View Details
Hi, We need a token placed in Plan Views to show position of camera mid-point referenced to World UCS:
Token or Script for Camera positionToken or Script for Camera position
Thank you,
Ilko Dimitrov
ACBS
6 Kommentare
Emanuel.Nestor
Autodesk Support
Status geändert in: Gathering Support
It might be great if the Camera object will have also the "User attributes" fields like any other AS object.
The Camera labels should be able to access / use these attributes.
Thank you
Emy
acbsdesign
@Emanuel.Nestor
Please vote if you agree with the idea, otherwise, it won't be considered.
acbsdesign
User attributes will require manual entering, (typos and errors), there should be a way to add Z-value of the camera midpoint as a token.
pshtewankareem
do you mean this
https://youtu.be/zQAKypTky9A
acbsdesign
@pshtewankareem
No,
It is not what you have uploaded on Youtube,
We need a token referencing the elevation view to the grid line where the elevation is created..
Detail Title would be "Elevation along Grid Line A" for example.
Currently, we do not have this simple functionality in AS2020 version, decades after AS was introduced.
No matter what the sales guy with the success stories says,
real-world workflow is not for story-tellers.
acbsdesign
@pshtewankareem
Sorry, I meant-"Plan view at el. 12'-6"(token)" - where the camera was created.
The other thing is as I wrote above-Token or any reference to the grid line where the elevation view was created.
https://forums.autodesk.com/t5/advance-steel-ideas/token-quot-grid-line-quot-in-camera-views/idi-p/8...
Idee einsenden
