When opening Advance Steel - Tool Pallets in user category
Hello
Many users wish to have Tool Pallets in user category when opening Advance Steel
Seen with Autodesk support, it is not possible for the moment
so please vote
To enable this development
Regards
Corentin PRIGENT
9 Comments
A million times yes! Ianyone has changed the logos in their BOMs, or has custom processes this needs to be changed every time they start Advance Steel.
Please add these as Managemnt default options
Schlemar
Sorry, but I don't understand the problem.
Can you show a screenshot of what exactly you mean.
krnavek
Yes, it is good idea. I voted for the Idea.
Anyway, there is a workaround - you can disable all styles in the Advance Steel category. Then User category is default.
Robert Krnavek
corentin_prigent
Hello, thank you all, thank Rob and Krnavek for your details !!
 M.Schlereth please look this screenshot : "Tool pallet user category"
corentin_prigent
Schlemar
Hello
You can deselect the Advance Styles. Then You will see only the User Styles.
But you have to be sure that all Styles deselected.
Take a look in Management Tools - Table Editor and search for DetailMasterTable. Here You can also switch off and on.
For Example the Drawing Style Manager.
corentin_prigent
Thank a lot  M.Schlereth for your details
But like Krnavek said it's a workaround.
It will be better to create  a Management  Tools option
Hi at all,
In the following link of the forum, I show a SQL script. With this script, it could be done to uncheck the all these in one step for detail styles, processes and bom templates.
You could use the Microsoft SQL management Studio or in general it should be possible to do this by using the command line of windows. Maybe I add this later in the thread.
Here is the link: https://forums.autodesk.com/t5/advance-steel-forum/can-i-assign-a-default-drawing-style/td-p/9266100...
Julio_Soto
I don't feel like unchecking the boxes is a workaround. You only do it once at set up and never have to set it again. I feel this is extremely easy to do.
