VERTICAL GRIDS
VERTICAL GRIDS
At this moment we can't see vertical grids in model and not in drawing .it makes our modelling work very hard because we can't do any work in elevation .because we don't know from where my slope and and any other things starts in .At the time of drawing we have to put manually grids in drawing from line command it is a heavy task so.
29 Comments
It's 2018 and we still need grids to be 3D and easy to use without copying..
bentleydetailing
That is why I call Advance Steel Tekla light, Grids lines are still a big issue to me.
Even in Autodesk Structural Detailing on which I was working for 4 years, the grids weren't a problem at all. They were visible all the time and it was one-click action to delete them without any effort.
Aaron485
Is this still in the works?
will5L99Z
Whats happening with thi supdate?
I have will with advance steel for 9 years, the grid lines issues make the detailing work to be high risk of mistake cause other software like strucad and tekla, always using grid the control the exact location. I trust that AS will need it and their team will soon have this.
DumitruBerteanu
Status changed to: Accepted
DumitruBerteanu
bigcarl5000kg
great 👍👍👍👍
