Transparency in Drawing View elements
In the drawing views I can select for each object, if they show their hidden edges or not. I would need an option to set the selected object "transparent", to show the elements hidden by this object.
Consider: you model a slab and for completeness you also model the Floor (let's say there is a flooring Construction of 160 mm built on the raw concrete slab). Creating a View, the floor construction hides the beam connections, whilst they stand on the raw slab. I don't want to hide the floor (in a Section view e.g.) to be able to use it for dimensioning.
So turning it "Transparent" would maintain the edge and makes the connection details visible...
(my Constuction-spec english may not be perfect, so sorry for some incorrect terms Smiley Happy)
BR,
Daniel
1 Comment
haedicu
