This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Step Export
Step Export
I have brought this idea though already once, unfortunately, it is voted not enough, although it so many users need.
Finally, Advance Steel must bring an export to Step.
Just for the cuts reaping of complicated cuts in pipes.
All manufacturers of these 3D lasers robots need the Step format.
14 Comments
Austruct
The Step import and export functionality needs to be looked at, its becoming critical for interoperability.
we will have a look at it.
The step export you are talking about is only about hollow sections, right?
I am asking because there are other requests for STEP export as well.
Gernot
ETheuring
Hi Gernot,
no, it will be better, if one can export a STEP for every Advance Steel Objects.
Hollow sections are one of the critical objects. Pipes and Plate there are also important.
Regards
Elias
Ok, but then we are not talking about pipe-laser support anymore.
@ETheuring : I can call you to discuss.
Gernot
jcalosa
I have to create an app just for this. It's disappointing that such a widely use file is not available for conversion.
Jonathan.Jasinski
is the "Export CIS/2" not what you are looking for.  It exports models to .stp files (which I believe are the same as .step).  I may be wrong here, but just a thought.
ETheuring
No, the CIS/2 exports is a special export between CAD systems or to ERP systems.
Though the CIS/2 exports also has the file ending *.stp. However, this is not the same as Step. You can test it yourself. You can export a CIS/2 and try, this file about the AutoCAD import as a Step import. This will not work.
AleckGiles
Until Autodesk add such functionality to Advance Steel / AutoCAD the Graitec Powerpack for Advance Steel includes a function to export to ACIS, DWG (3D Solids), STEP or IGES files. This can do your whole model or selected parts to individual files named after the part numbers.
ETheuring
I have generated this entry because I believe that the Step format should be a standard export format in Advance Steel.
The fact that we have inserted the format in the Graitec Powerpack with, is aware to me completely and it is nice that we are able to do this and I hope that many users our Powerpack shop just, therefore.
Since the Graitec Powerpack for Autodesk Advance Steel still holds ready many other surprises.
https://www.graitec.com/powerpack-for-advance-steel/
RussellNorman
Observer
I have need of exporting to step format also.
These are required by fabricators for their laser cutters. I have tried the method of exploding the advance steel model and then using AutoCAD Mechanical to export the file to step format, but this doesn't export the mark numbers of the beams, nor does it do it individually as required by the fabricators. This way has many potential errors doing it manually....especially when there are 100's of beams.
Can we please have this automated in advance steel?
eric_pilote6QKNS
Observer
Do I need the power pack option to be able to export to STEP from advance steel ?
I tried to explode my drawing and open it on autocad but I still can't export to STEP ...
someone can direct me about it ?
maebingerEX3UQ
Not everyone has a need for PowerPack. But they do for Stepexport. It should be a standard in AdvanceSteel. It is uneconomical if you have to buy an extra PowerPack for it.
bigcarl5000kg
@maebingerEX3UQ,
another way to do this is to use Autocad Mechanical, for example as part of the AEC collection
maebingerEX3UQ
@bigcarl5000kg
We are currently doing the same. But that's only a temporary solution.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
