Select multiple when editing
When selecting the editing boxes for features applied to an object, multiple should be able to be selected. Currently for example, if selecting the feature box for an object that as been 'cut at an object', you must select the features box, right click, and select Advance Joint Properties... and edit each one, one by one. (A bit time consuming.)
(Now, I realize, we can create a joint group, copy it around and it will now be a master, however...) All items that are able to be selected, that would bring up the same macro, should be able to be executed with multiple of the same type selected.
1 Comment
haedicu
