Select assemblies by right clicking
Improvement request received via Technical Support:
It would be nice to have an option to right-click on an object and then to be able to select the entire assembly from which that object is a part.
Eg: on a beam assembly, right-click on an object and then "select assembly" to select all the assembly. Similar to the two-step process that we now have: mark objects connected in the shop and then select marked objects.
Thank you!
Bogdan
2 Kommentare
acbsdesign
Hi Bogdan,
Copy the _AstM4SwitchReprMode MAINSTRUCTURE  command to the edit menu in the shortcut menus. (Toolbar is from AS2014)
Regards, Ilko Dimitrov
acbsdesign
I have also added the following command to the Default Menu "Clear Marked Objects":
^C^C_AstM4CommUnmarkObjects
Ilko Dimitrov
Idee einsenden
