When using the railing macro with the option to "select the nosing point relative to the start point" the top railing can easily be set to a certain height above the nosing point regardless of the beam location (ex. 42" above the nosing). This is great for getting the top rail at the right height! However, when trying to set the middle handrail locations the reference is off by the nosing offset distance. If you try to use "distance from top" to set the middle rails you will notice that the reference location is not actually from the top of the rail but the top of the rail minus the nosing offset distance (see attached example - the "distance from top handrail" is set to "0" so theoretically middle handrail and top handrail should be aligned - they are off by 1 1/2" which was the nosing offset distance).
It would be great if this could be changed so that when setting the middle handrail "distance from top handrail" actually referenced the top of the railing no matter if the "distance from nosing point" option is chosen or not (on the "top handrail" screen).
