"Numbering by True geometry" option
Actually, parts with the same final geometry can have multiple part number (hole in hole,...).
It would be nice to have an option to number by true (final) geometry.
4 Comments
haedicu
Status changed to: Accepted
thanks for highlighting this issue. There is a default in Management Tool to set the requested behavior:
This checked, will give you the same number for 2 elements. However at the moment you will not get all parts with the same number. We will look into this one.
best regards
Udo
BenBraspenning
There is an option in the management tools ignore holes inside slots or other holes.
It's only working for external standard parts.
I want the same option that can be use for in the model.
If the part is looks the same, I want the same number. Also when in one there is a hole in a hole.
Ben
Emanuel.Nestor
Autodesk Support
Hi Ben,
It seems that there is a similar request in this post:
If you think that the above idea will solve your request too, please vote for it.
Best regards,
Emy
BenBraspenning
Would be verry helpfull!!
Ben
