Plate Numbering
Plate Numbering
I would think it would be useful if there was an option to number plates in Management Tools by thickness. This would make it easier for my customers when the send the plates for processing as all plates of one thickness would be in sequential numbering. The way I currently do this is that I have a series of queries set up in my template file that isolates the plates of particular thicknesses then number these individually. Better for processor and better for client.
If there is already a way to do this I would love to know.
1 Kommentar
acbsdesign
@Anonymous,
It will be also great  if all material is numbered per type, size and thickness.
This will make the Advance BOM with preliminary numbers sorted per type, size and thickness easier.
Currently, if we need to assign preliminary number per size and thickness we have to select each size, type of profile, thickness for plates etc. and run the numbering.
This requires extra time to do the Advance BOM sorted the way fabricators want to see it
I submitted this in the past to Heiko, it did not get implemented. After that I submitted it to tech support, same result.
Hopefully this will be implemented now.
Ilko Dimitrov
Idee einsenden
