Option to set the view rotation in DSM
Currently, a view can be rotated in detail drawing only manually, after generating the detail.
The request would be to have the option to set the view rotation directly in Drawing Style Manager, in the detail style definition. In this way, the view is generated rotated automatically.
Thank you
2 Comments
bigcarl5000kg
It would be enough if the expected section rotation was correct, if views and sections could be rotated in increments other than just 90° with working automatic dimensioning and hatching... well, there are so many illogical functions and bugs that Autodesk needs more than another 7 years to identify them and then the same to initiate the remediation
Flies-Eyes
@bigcarl5000kg allocating parameters to Camera objects to provide better control for automation would much higher up on my list.
