Keep RDF files registered when copying the project
Hi Devs, RDF files do get de-registered and cannot be registered again if we copy the project (back up for example).
 Please implement this asap, we plan on creating rdf files in dwt templates, build a model, update already created rdf files, and produce external lists. Thank you.
2 Comments
should be solved, if the model database (*.mdf) will also be copied.
acbsdesign
@Sebastian_Eiche
Thank you for your help.
MDF file should be kept within the project folder with Details, BOM etc.
This will make things easier in the everyday workflow, but not a big deal if remains as it is now.
