Improvements to view tools and project explorer
Hi Devs,
Please improve the view functionalities of AS. It is nearly impossible to effectively manage the views of objects in large models. The quick view functions work fine, but there is no way to return to the previous view state after that. Only way is to use the all visible command which turns everything on and resets all the current filters/settings in the project explorer. This then takes a long time to get back and pretty much negates any advantage in using these tools.
Maybe a simple "previous visible" type function which returns to the previous view state?
In relation to the project explorer, we really need:
1) The ability to turn several elements on or off collectively.
2) An "all on except" and "all off except" option for groups/queries/levels...
Cheers,
Dart
1 Comment
This is not a fix by any means and you are probably already doing this .
  I always try to select all items I wish to keep in view before pressing all visible and just add the additional Items I need to view to the selection before hitting the "show only selected objects" button and can instantly add those elements to a named group in the project explorer.
I know its not solution by any means but Hope it helps someone
