I can't change the material directly in Model Browser
hi,
When i change the material in Model Browser is look good, but when i do numbering all material value are back to there original.
The issue is ta change the material in property panel but in 2016 i can do this direct in model browser and it help a lot.
thank you
2 Comments
iwafb
This sounds like a bug in 2018? Especially if it has worked in previous versions. Did you report to Autodesk?
Yes its a bug and i report to Autodesk
