Change hole tolerance out of the connection or macro
hi,
i need to improve the concept of hole tolerance.
EX 1:  When i Create stair i can manually select bolts and change the hole tolerance but when i use shear plate i can't. (yes but in connetion)
What i want to do, is to use filter search to select all bolts i want and change the hole tolerance direct in property panel. (for all bolts and anchors)
** I use it when i work wiht galvanise or weldnuts **
