Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Eliminate unnecessary dimension to flange edges
Per attached screen shot, example-column section, there are dimensions referenced to flange edges.
Common practice is never to dimension holes etc. to flange edges due to rolling tolerances.
Please remove all dimension requests to flange edges for all dwg styles, it will save us time and prevent errors in the shop.
This also applies for rolled edges for angles, NISD requirement is to dimension holes from base edge, not from free rolled edge of the angle.
Thank you,
Ilko Dimitrov
4 Comments
acbsdesign
This is another example-column-front view-dimensions are given to edge of flanges.
haedicu
haedicu
Status changed to: Archived
Due to a low support of your peers, your great idea is not considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
 angles being dimensioned form the rolled edge or toe is NOT a standard detailing practice, so many basic detailing practices this program does not follow, the boss said "Get a new program"
