Drawing styles for end treatments improvement
Per attached screen pic-if we have a pipe cut at another pipe, element contour-rule-dimensions are very messy and require cleaning.
What we need is only two (or3) dimensions-depth of radius cut, radius valuue, and if dept is different (cutting element skewed - angle different than 90 degrees) , second radius dept.
Ilko Dimitrov
1 Comment
haedicu
Thank you for this idea. I agree that this will help reduce time to clean up drawings. An idea to overcome this situation is to use a separate drawing style for these tubes. By using model roles it could be also included into the drawing processes.
However we will take it in consideration for a future release and think about, what would be the best way to implement.
best regards
Udo
