Distance command in Joints
Sometimes I need to measure certain things while I am creating a joint, currently if you do a distance command the joint dialogue box closes.
It would be great to be able to use the distance command while keeping the joint dialogue box open in a similar way that the 3D Orbit, Pan and Zoom commands work with the joint dialogue box open.
3 Comments
iwafb
Users have been requesting this and other dialogue improvements in the macros over several threads for years...
Advance Steel Team/ Developers!!
Please look into developing these small requests as these small fixes can aid significantly in productivity.
alickomay
if making autocad treat the distance command differently to others  (as in not close macro if type "di" ,  but will close macro if other command)
insted  add a mesher button to bottom right of macro window
