Delete allready connected beams with all it's features
Is there a command that deletes all the feautures from the beams that are allready connected. So welds, bolts, plates, joint box etc.
I have a building that is final, and now the client wants the whole roof edge to be deleted. How can I quickly delete all beams with it's connections?
Please can somebody help out?
Otherwise I think this is a command that is much appriciated within AS for all the users.
2 Comments
maybe a forum post first would be easier than an idea post, because not so many are looking in this area.
To your question:
There's no button already there, but it's easy to do it. The command is: "display connection means" this will mark up all connection elements from the objects which is selected. So after this the command: select marked objects will select them. So with the following steps, you could select the beams and then use the command.
  • Remove marking+ display object connected in shop
  • select all marked objects
  • display connection means
  • delete
The combined command is:
^C^C_AstM4CommUnmarkObjects;_AstM4SwitchReprMode;MAINSTRUCTURE;_AstM4CommSelectMarkedObjects;_AstM4CommMarkConnMeans;_AstM4CommSelectMarkedObjects;delete
TvdH1981
Thanks, I found out myself last week. Coudn't delete the post.
