Coordonate part detailing direction with NC / DXF orientation
Currently there is no direct link or correlation between a beam orientation in detail drawing and the orientation in NC / DXF file. When the NC orientation does not match the detailing orientation, it is difficult on the fabrication process to review each NC file and detail drawing.
The workflow to ensure these orientations match is to use the NC orientation as reference (since it cannot be altered by user), and to set the detailing direction to match the NC orientation.
For reference, there is an article with additional info about the current behaviour:
The feature request is to implement an option or a mechanism to link the element orientations in detail and NC / DXF files, so to be sure the orientations match.
As example, an additional option in Drawing Style Manager on the “View arrangement” page, next to “Orientation of the beam end” and “Orientation of the views”.
Ideally, when activate the option, the NC orientation should be changed, to match the drawing style settings; however, the DSTV-NC orientation rules must always be respected.
For symmetrical section (like I, Rectangular Hollow Section), it should be possible for any DS setting.
For non-symmetrical section (like Channel): if it is possible, then the NC orientation should match the detailing orientation. If it is not possible, than the NC orientation has priority, and the detailing direction will follow.
Thank you very much
Emy
