Drawing updation
Drawing updation
Hi All,
it will be good for us if As tells us what is revised in drawings by making clouds on the things which is modified in the drawings . As we still have to compare Drawing with the pdf to figure out the changes ..... it will save our huge Rechecking time....
2 Kommentare
Rob_Merriman
 @ArjunGaba
Do you use the update revsion function in the document manager, this is what the system does already or am i miss understanding your query
See webpage below
https://www.graitec.com/autodesk-advance-steel/revision-control/
ArjunGaba
@Rob_Merriman  Actually the Query is about Advanced steel automatic cloud the area which is Updated....
Idee einsenden
