Change the current definition of the weld in model data from text to modern graphic interface
The current text interface for weld definition in the model data is in 21' century unacceptable. Please change this to the graphic version like in AutoCAD Mechanical.
Advantages of graphics method
- it is clearer / more accurate for the user
- the welds created here can be saved in the library
- definitions can be imported from another dwg
Disadvantages = NO
AUTODESK, please use what you already have in stock ...
1 Comment
acbsdesign
We definitely need this added.
