Bent plate in IFC export
Currently, bent plates are NOT exported in IFC regardless of format (2x3 or EM.11, neither show bent plate).  We use tons of bent plate, I don't feel encouraged to use IFC for BIM coordination.  I currently explode the model to solids for coordination, which is less than ideal.  It also means I can't use IFC for fabrication info (plasma, press brake, etc).  Please fix.
2 Kommentare
mick-CNF
What bent plates are not exporting?
Bent Plate | Search | Autodesk Knowledge Network
abeeler
No bent plates are included in IFC MVD EM.11.  I have to use this format with my ERP software because IFC2x3 doesn't include part reference numbers.  Damned if you do, damned if you don't.
Idee einsenden
