BOM for concrete pile data extraction
Hi there...
It's me again Woman Wink
How about adding a BOM for concrete pile Data extraction.
First example is of a typical table layout with the data that we need to include.
Columns we will likely fill out by hand would be:
‘NOMINAL GRADE ELEVATION’
‘MINIMUM PILE EMBEDMENT’ &
‘PIPE SUPPORT NO.’
If we can add the Section Type & Plate size (LxW) with thickness in a separate column it would be good.
For the elevations we need 2 (typically the ‘Z’ Coord).
The elevation at the top of the cap plate &
The elevation at the bottom of the cap plate / also known as the ‘PILE CUT-OFF ELEVATION’
Second example shows a Pile model which will have a number of Piles (steel section – either ‘W’ or circular hollow section with a base plate welded to the top end (typically central)) modelled.
The purpose is to supply a drawing / document with the data needed to locate and install piles to the contractor.
I have created the foundation of such a BOM for concrete piles mind you it is rather just the heading text and some tokens.
Perhaps the development team could elaborate on it.
Please see attached.
It would be nice….
Juss sayin: Woman Wink
Best regards,
Janet
Graitec CANADA
