Having an Aluminum and Stainless Steel material library is necessary for fabrication shops. I know you can add general libraries, but those do not add the properties needed in the model to show correct connections and weights. We need structural shapes like beams, channels, and angles.
Also, The KISS file standards need to be updated. Advanced Steel currently only produces a "D" line in a kiss file. It needs to produce all of the lines, so drawings do not have to be manually entered into Fabtrol MRP.
