Abilty to rotate veribale grating quikly
so i would like to be able to rotate variable grating's run direction   as in going from  grating 2 to grating 3 (see pic below)grating.PNG
now  it is very esey to change 2 to 3 u can clik on grating select grip point of rotate thing in midel and then select the mid point of the other side of the grating
but  in reality grating offen got lots of notchest  ,  and so the mid point no longer works , and for sum reson even if u have  un-notched corners  u would think u could use "midpoint between 2 points" to snap to midpoint of grating but no this dont work, repeted it 3 time's never work dont know y
so u need to put in a construction line and move it to the rite  place then use it to snap to , witch depending on how u count its 16to19 steps
16 steps to rotate a bit to grating
l
enter
click center
click to side
esc
click line
m
enter
click any where
move mouse up
12.5  (could be considered 4 comands)
enter
select grating
select rotate thing grip point
clik end of line
 esc
now lets see if we can do thins in 4 steps
double click grating
click positioning
click rotate 90 (see pic)
esc or click X
3 Kommentare
bullit2312
this would be a great addition.
DumitruBerteanu
Status geändert in: Under Review
rmouton
Please implement this
Idee einsenden
