3D grid
3D grid
Advance Steel needs projected 3d Gridlines like any other 3d program. You shouldn't have to copy the same grid to every level. The current workflow is outdated and requires way too much manual work to get something as basic as grids working in plans and elevations, when you want to have plans of two or more separate levels.
8 Kommentare
iwafb
Good news. This has already been accepted on the following thread:
https://forums.autodesk.com/t5/advance-steel-ideas/vertical-grids/idi-p/6031371
alec.melville
@iwafbThis is not what i meant. You currently need to make separate grids for every level in your model. Your grid should not need to be in the view range of the camera to be projected on to the drawing in plan views.
iwafb
Yep, that's what I understdood. 3D grid discussion is at the end...
alec.melville
@iwafbso am I understanding this correctly that it has been accepted over 3 years ago and it still hasn't been implemented? That is kind of sad =(
bigcarl5000kg
That's normal ... that's the reality ☺️
alec.melville
@bigcarl5000kg Well, maybe a new thread will show autodesk that there is still interest in this feature and if they have forgotten, we the users have not :grinsendes_Gesicht_mit_lächelnden_Augen:
bigcarl5000kg
@alec.melville I hope, we as users, are still visible for Devs ☺️
Adrian_Gantoi
Observer
Hi everyone, have you seen this tool in the Graitec PowerPack ?
Idee einsenden
