why when i weld on kp to beam dose it change the part mark of the 12 fin plates (f23)
all other plates stay same, only kp should go from sum f-xx to kp-xx
i can fix the plate name by pressing undo heaps of times then renumbering (i have repeated this 3 times now )
but i kind of wont that kp welded to beam
all plates have bean cut an marked by plasma
all drawing printed
i was hoping to only redo the one assembly drawing but now it looks like all drawing go to go in bin or plates not going to match, 170 pages in the bin Greta will be pissed
Solved by AleckGiles. Go to Solution.
Could it be that in your Number settings you have some boxes checked in "Unique mark per object" or "Overwrite prefix"? It sounds like some of the settings under the Special tab need to be adjusted.
Before welding the kick plate to the beam has the part number 23 been manually assigned to it? Making it KP23. It seems that way.
When you weld the kick plate to the main beam it stops being a standalone part so the part number and assembly number no longer need to match. The part number gets a new prefix of F for fitting but the system does not seem to be able to change the actual number of 23. In my experience, this only happens when the number has been typed in manually.
Since the kick plate is now F23 the find plates can no longer be F23 so they get a new number.
To avoid this you must remove the existing part number from KP23 before renumbering. You can remove the existing part number from just that one part as follows:-
Now the Kick plate will have no part number. You can renumber the whole model.
Aleck Giles, Structures Consultant, Graitec
