Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
X - Bracing middle connection
6 REPLIES 6
S.MANICKAVASAGAM
694 Views, 6 Replies
Dear Expert,
                Which macro to be used for X - Bracing mid point for back to back angle section.
             I tried but not get, please to be guided.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
6 REPLIES 6
@S.MANICKAVASAGAM
Please use the attached Macro from the picture
Dear Expert,
                     Thanks for your reply.
                 I tried the same connection as per your mentioned. But not get result.
                Please to be attached any screencast  video.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
@S.MANICKAVASAGAM  Please attach screenshot or Screencast
Dear Expert,
                       Thanks, I get connection through compound section change to separate beam option.
                    But, in connection nut not display. any mistake from me.?
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
you maybe use the wrong bolt...could you show us which one do you use?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
@S.MANICKAVASAGAM  Check your bolt layout it will clashing with anything that's why it is not showing nut or  Can be wrong bolt type used..
