Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
wrongly generated dxf files
2 REPLIES 2
fejkKZ7V8
463 Views, 2 Replies
Hello, is there any way to generate correct dxf and nc files for plates with preparation for butt weld on the edge (_AstM14CommAddFeatEdge)? I'm not able to read nc-files but from workshop they call me moron because of wrong dxf-files (i did not check them). I tried almost everything even our distributor's support nad i did not found anything. I tried to generate files in versions AS 2017 and 2020. Funny thing is that with ten plates only nine of them wrong (please see attached file). I'm I doing something wrong?
Thx for your advices
Fejk
Tags (3)
Labels (3)
2 REPLIES 2
Sebastian_Eiche
in reply to: fejkKZ7V8
the problem is: you don't use Weldpreparations...
You use "cut on ucs" or something like that. Weld preparations are defined as objects in the NC and DXF files, so for having them, you had to use the command for it:
And if you do this, the DXF and NC files are correct
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
fejkKZ7V8
in reply to: Sebastian_Eiche
thanks a lot, results are much better however not entirely correct (please see attached file) but it seems to be an applicable solution. Unfortunately work with this "weldprepartions" is less userfrendly.
Fejk
