wrong view on detail drawing
This widget could not be displayed.
Can anyone tell me why the one time i get a front view and a top view of my beam and on another drawing a front view and a bottom view ....??
These are both beams so i dont get it...
Rob_Merriman
Hi @Anonymous
So on the first view you have gusset plates in the Web so the system will run a top view to position those
For the second beam there are holes in the bottom flange so the system runs a bottom view to show and dimension those, if you had top flange holes on this beam you would get a top and bottom view
These views are controlled by the nessesary view wizard
Rob Merriman, AEC Technical Lead, Graitec
SanjoyNath
Dear Experts,
I think the Front view of the main part is hardcoded or somewhere deep inside the databases(AstorSetings)
For every profiles the Front view decider is prefilled which controls v, u o h,  conditions of NC files also
And also for ECS(Entity Coordinate Systems for auto set of camera)
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
