Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Welded join
4 REPLIES 4
1608 Views, 4 Replies
Welded join
Hi everyone,
Can anybody tell me how to do a welded connection between two beams?
Labels (1)
4 REPLIES 4
andrewWCZBN
Use the weld point function, this can  be found on the ribbon - home - objects.
select the objects to we welded together and press enter.
If you also need to notch a beam into another, you can use the tools on the advance steel tool palette.
I hope this helps
in reply to: andrewWCZBN
Hi, i have the same issue.
Where I can find this tool? I use 2021 versione.
Also I would like to know if a connection made with handrail fitting joint, realize a welded connection (see figure),
Thank you very much.
andrewWCZBN
Hi @Anonymous
The weld point icon is on the ribbon, in the home tab (circled in red in the post above).
If you have used the railing joint from the connection vault then this will have introduced a weld, if you have used the mitre tool then it will not.
You can check if items are welded together by using the "Display objects connected in shop" tool. this can be found in the Advance tool palette as shown below.  It will highlight the selected assembly in red.
Thank you very much
