Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Weld Pad Base Plate
6 REPLIES 6
chad.corkern
563 Views, 6 Replies
Weld Pad Base Plate
I have created a custom connection that is a weld pad base plate. The problem I have is that, it comes in perpendicular to the angled column. How do I get it to come in square to the world?
6 REPLIES 6
this is a setting in the baseplate connection.
double click on the customer joint and "allow editing" , then open the baseplate connection and in the baseplate layout you could set the alignment:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
mick-CNF
in reply to: chad.corkern
Just curious but what makes this a custom connection?
I looks like a normal base plate?
If this information solves your problem please accept as a solution.
chad.corkern
in reply to: mick-CNF
I'm trying to build a weld pad. The anchors themselves would be welded to the base plate and embed in the concrete. When I try the base plate function I don't see that as an option. So I created a custom connection. If there is a better way to do this I'm happy to hear?
mick-CNF
Hi again,
what is on the bottom of the anchor?
chad.corkern
Right now I've extruded the shape of a headed stud.
mick-CNF
You could create an anchor to use in the base plate connection, the only issue is they are not welded to the base plate.
