Announcements
Weld line to show up on drawings.
Priitl220
Priitl220
How to get the weld lines to show up on drawings?
I have drawn welds by "line of weld command".
When I generate drawings I see no weld line, only labels.
What settings should I use in Drawing Style manager for Weld line Object Presentation?
I would like the welds to show up as by using command "insert weld line" on drawings.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @Priitl220,
Thank you for using Advance Steel Forum 🙂
The weld lines from the 3D model are not shown in the detail drawing. Only the weld symbols / labels are shown, like for weld point.
This is a limitation of current implementation.
Maybe you could post a feature request on the Advance Steel Idea Station portal - to enhance the current behavior. In this way other users are able to contribute and vote for your idea, while the management team is actively monitoring this portal.
I wish I could help you more on this.
Best regards,
Emy
Emy Nestor
vuk.vukanic
@Emanuel.Nestor
so the symbol is only available when done in the drawing directly?
this post takls about the same thing, as it is possible, but I havent managed it yet...
https://forums.autodesk.com/t5/advance-steel-forum/weld-representation-in-drawings-section-symbols-a...
Thx
Easy things are not worth the effort
http://www.teamcad.rs
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @vuk.vukanic,
Indeed, the weld line symbol (the one you get by using the command "Insert weld line" in the detail drawing) can be created only manually.
You cannot add it automatically, by customizing the drawing style.
Best regards,
Emy
Emy Nestor
arkli2009
Is it possible to make it work with drawing style?
Paulo_coimbra
Community Visitor
Community Visitor
Bom dia
Quando estou a utilizar o Advance Steel na elaboração de desenhos de detalhe, quando quero selecionar soldaduras nos desenhos, só me aparece a linha de chamada e não aparece o simbolo do tipo de junta/soldadura.
Conseguem me ajudar?
"Good morning
When I am using Advance Steel to create detail drawings, when I want to select welds in the drawings, only the leader line appears and the joint/welding type symbol does not appear.
Can you help me?"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
Dias_Antonio
@Paulo_coimbra
O símbolo do tipo de junta está relacionado com o arquivo dentro de um desses possíveis caminhos. Verifique se o símbolo da junta que você necessita encontra-se. Caso não há deve-se criar utilizando o AutoCAD para depois seguir com a apresentação dele dentro de uma estratégia definida no Drawing Styles. deve-se verificar se a propriedade Visible para este tipo de objeto está com o status "Visible" ou "Hidden".
C:\ProgramData\Autodesk\Advance Steel 2023\USA\Shared\Support\Symbols
C:\ProgramData\Autodesk\Advance Steel 2023\BRA\Shared\Support\Symbols
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
