Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Weight incorrect in single part title
7 REPLIES 7
Message 1 of 8
803 Views, 7 Replies
I have extracted out single parts and have noticed the weight token in the description is incorrect. It should be 58.7kg but it's coming out as 58723.4882 kg? How can I fix this?
See attached snap shot.
Cheers
Jeff
7 REPLIES 7
Message 2 of 8
Dias_Antonio
Hi Jeff
a) Did you check if the units are OK in AAS? (Type units)
b) Did you check if the units default in Advanced Management Tools are OK?
Att
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Message 3 of 8
in reply to: Dias_Antonio
Yes checked those, but still the same?
Message 4 of 8
Emanuel.Nestor
Hello Jeff
Thank you for posting on Advance Steel Forum 🙂
If you are working on a Windows 10 machine and you have Avast Antivirus:
- try uninstall this antivirus and test again the behavior.
Please let me know the results of this test.
Best regards,
Emy
Emy Nestor
Message 5 of 8
in reply to: Emanuel.Nestor
I'm not working on a Windows 10 Machine and do not have that antivirus.
Jeff
Message 6 of 8
Emanuel.Nestor
Hi @Anonymous
Thank you for info.
Do you think you could add an archive with the model and the detail drawing ?
And additional question: is it happening for any project or only for one particular project ?
Best regards,
Emy
Emy Nestor
Message 7 of 8
Emanuel.Nestor
Hi @Anonymous,
Please open your detail drawing and open the Project settings dialog:
- Ribbon --> Home --> Settings panel --> Project settings
Then check the tab for Weight units.
Do you have something like in the attached picture ?
Best regards,
Emy
Emy Nestor
Message 8 of 8
Thanks very much.
I thought I had it correct as per attached.
Cheers
Jeff
