Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Vertical Ladders
3 REPLIES 3
1631 Views, 3 Replies
Vertical Ladders
I have just created a vertical ladder within advance steel, However when I wish to include a cage at the ladder top exit, all  the options to add the top cage are greyed out. I have attached a couple of screen shots. Does anyone have any idea why this is happening?
3 REPLIES 3
Unfortunately this is a limitation of Advance Steel. At this point a top cage can only exist if the Ladder Exit is set to "straight".
Tags (1)
What I would do in your scenario is model the Cage Ladder with the intelligent Macro to as close to your requirements as possible. You will then need to add the top cage in by manually modelling in this part of the Cage Ladder. The best way to do this would be to use AutoCAD Lines and Arcs in the correct locations. Then use the "Beam from Line" to convert these to the required flat sections.
You can then use the "merge Beams " to merge the seperate parts into one beam and weld this onto the Cage Ladder.
Hopefully Autodesk will add this capability to the Cage Ladder Macro in the near future.
Tags (1)
Thanks for your quick response, I will have an attempt at what you described.
Its just a pity you cant complete some of these standards details without some form of manipulation.
These types of vertical ladder are common and are taken from most European codes.
Many thanks again.
