Hello Everyone,
I am wondering if there is a way to change the user attribute names, to a custom name rather than a generic number. Please see the image below. Thank you for your hints. Regards
Solved by bigcarl5000kg. Go to Solution.
Hi @Csolati,
of course it is possible ... go to Management Tools / Table editor ... load the databases ... and filter (use field under) for ErrorMessages ... in a column ErrorText search for the descriptions you want to change (click on the column name to sort descending/ascending)
HTH
Hello Carl,
Thank you for quick response.
I have changed the user attribute 1 to something else and still the text not showing in Advance Properties. To be honest I do not understand the connection between the header text of UDA to error messages! Am I missing something? Thank you.
Shoooooot! Found it. I had to change the Ugurs Property Sheet table. Thank you Carl. You are very knowledgeable. Much appreciated! Image below is as a reference for others with the same question:
