Unknown and Up to Date
HarryHighpants
Message 1 of 11
HarryHighpants
How can a drawing be 'unknown' and 'up to date' at the same time ?
Actually, what does 'unknown' even signify?
Replies (10)
Message 2 of 11
wtheron
Expand the selection tree to see which components on the drawing is unknown. It may be a view or a part number. Use this information to query the model and take it from there.
I have also previously encountered this, the solution is different everytime.
Message 3 of 11
HarryHighpants
Ok, so I expand the node and it points to a BOM table which is empty.
I right click the table and update it.
The drawing still remains in the 'unknown' tree. What next?
Message 4 of 11
wtheron
Hello Harry,
Can you try the following. From the document manager expand until you find the list again. Then right click to delete this object. Close the document manager and re-open. Check to see if it is still listed as unknown.
Message 5 of 11
Please forgive me if this is a dumb question, but I noticed that the "Unknown" drawing title ends with "B-003.dwg" while the "Up to date" drawing title ends with "A-003.dwg".  Are they actually the same drawing?
Message 6 of 11
HarryHighpants
You're right, I circled the wrong drawing. The correct drawing was further down the tree.
Message 7 of 11
HarryHighpants
@wtheron wrote:
Hello Harry,
Yes, that fixes it.
AS sees an empty BOM and wants it out of the drawing.
Message 8 of 11
...and I should have read the whole list before posting!
Message 9 of 11
So back to the start "Actually, what does 'unknown' even signify"
Happens often. This is scary because I worry that if I delete them the drawings will also delete.
Its as if they are not registered in the model when they are.
AS please advise
Message 10 of 11
HarryHighpants
Dont delete the whole drawing, just expand the nodes and see what's the problem.
I almost made that same mistake, but wtheron put me on the right track with his post above.
Message 11 of 11
Yes I see what is happening but wonderiny why ?
Don't believe this should occur under what seems to be normal conditions.
Don't have time to correct it either.
