Unable to copy revision block in paperspace
CraigMWard
CraigMWard
Preface:
I'm copying my title block in paper space to allow me to have another "sheet" to display the excess elements contained within my viewport. I have this workflow figured out and isn't the issue. My prototypes are fine and working.
Question:
When copying the title block across, all the elements copy (project details, company logos, sheet details) the only thing that doesn't copy across is the revision block.
Is there a reason for this? can there be only one instance of this in paperspace? or is it a locked element?
bigcarl5000kg
it's not possible, you need to put in a new revision table ...
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
