Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Transfer of AS settings error
8 REPLIES 8
Message 1 of 9
johan.lotzN5C9R
465 Views, 8 Replies
Hi All
I use the following guideline to transfer Advance steel settings between our pcs in the office.
How to transfer all Advance Steel settings between two computers | Advance Steel 2019 | Autodesk Kno...
1/14 pcs this just won't work. If I rename the default installed (GBR) folder to (GBR Installed) and copy over the new folder, it does not read to the folder. I get the following error when opening Advance Steel:
If I delete the copied GBR folder and fix the renamed folder to GBR this message does not appear and obviously I have none of my settings. Even tried to do n straight copy and replace of the master folder but it does not work same error.
Any help would be great.
8 REPLIES 8
Message 2 of 9
do you delete the ldf files before starting AS
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 9
Hi @Sebastian_Eiche
Yes, I deleted the ASSettings_User.xml & *_log.ldf files.
Message 4 of 9
Do you have a look in the error log?
Sebastian Eiche
Message 5 of 9
Hi @Sebastian_Eiche
See attached the Error log.
I have uninstalled the program again, manually deleted the advance steel folder with all the previous year folders also.
Reinstalled the software, did not open anything.
Did the rename of GBR to (GBR Installed)
Copied the GBR that I want to use.
Ensured there is no xml or log files prior to opening the program.
I even ensure that the database is closed via task manager. (see below)
Strangely after I done all of this, and I delete my GBR that I copied and fix the original GBR name. It works instantly.
Message 6 of 9
Your Advance Steel want to connect to the wrong databases.
This is your error:
https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticles/...
In the article there's the part with "repair"...this is not possbile anymore (good idea from AD 😒) but kyou could delete the file and replace it with the xml from my attached zip file.
File to delete: ASSettings_Advance.xml
Folder: C:\Program Files\Autodesk\AutoCAD 2023\ADVS
Sebastian Eiche
Message 7 of 9
I would also check all the file access rights. Make sure the new GBR folder and all files and folders within have a user called "Everyone" with Full Access granted. If not you can get problems. Add the user if missing and make sure it is applied correctly to all contents.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Message 8 of 9
Hi @Sebastian_Eiche
Thank you for taking time with this very helpful information, but it did not solve any of my issues.
Message 9 of 9
Thank You Very much @AleckGiles.
This solved the problem.
Regards
