Token "UserAttribute" disappears when set in BOM drawing template
Dias_Antonio
Dias_Antonio
Dears Colleagues
I need that a specific User Attribute appears next to the Token "%Name", or replaced this Token in the same cell.
When I generate a first test for just the Token "%Name" everything is allright (see picture below)
After that I changed the BOM template to appear the "UserAttribute" (see picture below)
For my surprise the cell in column "Descrição" disappeared with no reason, not showing the
User Attribute that I have set in the model.
After a search in AKN, I have found this article
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
This article afirms that is possible to put a User Attribute Token in a cell inside a BOM drawing list (see picture below)
Anyone can help to find this issue?
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
markhubrich
I tested and it appears to work for me. See attached template file.
...and fix the kiss export issues.
Dias_Antonio
Hi @markhubrich
So, you created a new column with new Tokens?
Thanks for reply
Antonio Dias
markhubrich
No, I just changed the tokens in another template file and saved as new name.
Don't forget to make sure the group is still intact. If the line isn't grouped then it will not work.
I used to ungroup when editing in the past but now I just turn off "Group Selection" to edit.
markhubrich
If you can share your template file I can better see where you're issue is and fix it for you so you can learn from the example.
Dias_Antonio
Ok @markhubrich
Antonio Dias
markhubrich
Here's what I got changing the name token to userattribute1..
I also noticed when I first inserted your template that it was empty. This is probably due to the groupby field.
Here's a few observations:
1. the groupby field was trying to group by class which was not included in the line as a token. It should have a present token in the group it belongs too. I changed it too %Num.
2. the groupby field had it's own group. This needs to be part of the group you want to sort, or the template will be blank.
You can add columns. You just need to be sure that you include them in the group.
I attached the file. I hope this helps you understand better the workings of the BOM templates 🙂
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
