How do you make one hole through a steel structure? The options for the bolts/holes/studs aren't what I need. I just need a single hole.
You can do a single hole, the array would be 1x1.
Otherwise you could look at the Modify palette and punch a hole through of your own dimensions
Not sure what you mean by Hole through a structure ?
Perhaps the circular contour features from Advance Tool palette will give you what you need.
