Is there a limitation with adding threaded holes to a folded plate? I have been trying to fix a plate to a folded plate with a set screw and the threaded portion appears in the first plate only (non folded) I thought there may have been a problem with the bolts settings so modelled 2 plain rectangle plates and it was perfect.
if you have a look in the "objects" tab--ribbon connections objects--> drop down, there's an extra command for bolts/holes for folded plates.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
I'm having a very similar issue. I have 2 slotted holes and 1 round hole in a plate; but when I try to connect that plate to another plate (via "folded plate" option for a press broke plate) the holes disappear every time. I've tried "folding" the plates first and then adding the holes, but the holes try to insert into the wrong plane.
