I am getting an error message "The parameter is incorrrect" when trying to place a handrail on stairs. Any ideas on how to fix?
Could be a number of things.
Can you add screenshots or model?
It works for me, new dwg attached and screencast below.
Railing | Advance Steel | Autodesk Knowledge Network
Can you give a description or screencast of what is happening?
thanks for your assistance but im still getting " The parameter is is incorrect " errror message
Are you doing anything different to the screencast?
i know this error message. It occurs if your last generated railing cant be attached to this beam with a u-shape.
If AS cant do that it shows an error message instead of a red box around your connection.
So try another profile. Maybe just a flat bar or a T-Profile. After creating the railing change the basic parameters so it would fit to an u-shape profile and just save the settings and AS will take these settings for your next railing.
Maybe this will fix your error...
