tension rod - clevis
cristianUL24T
cristianUL24T
Is there a way to change the direction of the clevis and gusset plate. It is in slope, i want it to be perpendicular and direction to the other end diagonal Untitled19.png
Sebastian_Eiche
I don't think it possible automatic, but you could create the plate first an then select this plate instead of the beam.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
cristianUL24T
THANKS FOR THE REPLY, I WAS THINKING ABOUT DOING THAT, ANOTHER QUESTION, IS THERE A WAY TO INSERT A CLEVIS DIFFERENT FROM THE DATABASES IN THE MANO CONNECTION
Sebastian_Eiche
You could add lines in the database which I show you you in the other thread
Sebastian Eiche
cristianUL24T
IS THERE A TUROTIAL ON HOW TO ADD
Sebastian_Eiche
Not directly, I think you will find one or two threads for it here, but this is not miracle...just copy a line and change the things you want
Sebastian Eiche
